Author Topic: Odd results with hanging chains  (Read 4236 times)
iCreateLtd
« on: October 10, 2023, 01:57:14 pm »
Hi all
I'm having a weird issue with a hanging chain I'm trying to create.
What I don't show in the video is I've created a long chain base object & the pivot is at the top.
It's doing the opposite of what it's showing.
Any ideas why?
https://youtu.be/0uHdNJjvw7g
Re: Odd results with hanging chains
« Reply #1 on: October 10, 2023, 02:04:49 pm »
Adjusting its Direction settings under the Surface tab (which is set to 100 by default) to the Surface's Normal (0) should help. If needed, you can "flip" the surface.
iCreateLtd
« Reply #2 on: October 10, 2023, 02:08:23 pm »
Sorry, another thing I should have mentioned is that I'm using a path for distribution and nothing's plugged into surface.
Maybe I should send a file of just the chain FP
iCreateLtd
« Reply #3 on: October 10, 2023, 02:36:03 pm »
Hi Michal,
I've PM'd you a link to the max file of just the chain FP.
It's best viewed in alpha mode when rendering.
If you can take a look that'd be great.
« Reply #4 on: October 10, 2023, 03:12:31 pm »
That's because of using the Proxy Display mode - items used for this mode have the Pivot Point placed at the bottom. Instead, your Custom Object has the Pivot Point placed at the top. Using the Points-Cloud Display mode for the preview would be recommendable. I hope this clears it up.
iCreateLtd
« Reply #5 on: October 10, 2023, 03:20:15 pm »
Doh!!
That's great, thanks for the help
