Author Topic: scattering different plants  (Read 3426 times)
grue
« on: October 03, 2018, 05:20:55 pm »
i have a question, so what's the best way to scatter both tall wild grasses AND wildflowers scatter in there?
2 separate forest objects: i can use the same surface to scatter a) tall grasses and b) wildflowers
1 forest object: i can use the surface and add 3 tall grass custom objects plus add the 8 wildflower custom objects
i want to avoid the wildflower objects from creating a void in the tall grass objects, since the tall grass objects are about 3 ft in diameter, the wildflower objects are no bigger than 6-8" in diameter.  so wouldn't there be a missing grass object wherever there's a flower object, thus creating a "hole"?
thanks!
Re: scattering different plants
« Reply #1 on: October 04, 2018, 08:41:55 pm »
I would go with first option two ForestPack objects one for Tall grasses and one for Wildflowers.
I want to remind that You can use "Exclude Area" -> ForestPack object if that is what You want:
grue
« Reply #2 on: October 15, 2018, 03:40:56 pm »
thanks.  jeez, i forget that a forest object can be used just like any other object.
