Toggle navigation
Login
Register
Forest Pack
Forest Pro (*)
Rotation in angles?
« previous
next »
Print
Pages: [
1
Author
Topic: Rotation in angles? (Read 9170 times)
Nir Sullam
Jr. Member
Rotation in angles?
on:
August 22, 2010, 11:02:50 am »
Can I force FPP objects to rotate in angles 0,90,180,270 ?
I am distributing chairs in the gardens of a multi-villas project.
Nir
Logged
Administrator
Hero Member
Re: Rotation in angles?
Reply #1 on:
August 22, 2010, 11:17:17 am »
On defined angles by each item or randomly ?
For a random distribution, you can create four chair samples (rotated at 0,90,180, 270) and use them in the Geom List. If you need to rotate each chair a specific angle, the only way is to use the Custom Edit mode and scatter them using other object as reference (Creation Tools->Reference objects):
http://www.itoosoft.com/english/menu.php?id=forest_refedition
Logged
Nir Sullam
Jr. Member
Reply #2 on:
August 22, 2010, 11:24:02 am »
I need to scatter them randomly (each with a different rect. angle)
OK I will try the solution but maybe you could add it to a future version.
Nir
Logged
Print
Pages: [
1
« previous
next »
Forest Pack
Forest Pro (*)
Rotation in angles?
Welcome,Guest
1 Hour
1 Day
1 Week
1 Month
Forever
