Author Topic: Possible to Force scatter objects to orient objects along normals to a point?  (Read 2659 times)
cjwidd
Is it possible to use Forest Pack to scatter a number of objects on a surface that all are forced to rotate along their normals toward a point in space? (see attached)
« Last Edit: March 10, 2023, 03:06:53 am by cjwidd »
For these purposes you can use the Camera > Look At feature. When enabled, it rotates the items to look at a specified object (any node from the scene). This option is commonly used for billboards, but it also works with Custom Objects. I hope that helps.
