Author Topic: Override Dist. Map Scale?  (Read 3764 times)
Nir Sullam
« on: September 16, 2013, 12:31:21 pm »
Carlos
How can I fit a custom map to the area I I am using for the forest ? (like UVW Fit)
In the attached image I am trying to fit a custom map to the area marked as B Which is the total area but as you can see  many areas like A are spread all over . I tried playing with the mapping channel but nothing happenned.
Regards
Nir
Re: Override Dist. Map Scale?
« Reply #1 on: September 16, 2013, 12:54:26 pm »
Procedural maps take mapping from the UVW coordinates of the surface. Please check this:
1) The channel number is defined at Distribution->Map Channel (same value is used for all areas).
2) If you modify the surface, click Surface->Refresh button to reload it.
I just test it, and seems to work fine.
Nir Sullam
« Reply #2 on: September 16, 2013, 12:59:30 pm »
Thanks !
Nir
