Forest Pack => Forest Pro (*) => Topic started by: trimitek on January 08, 2016, 02:48:21 pm
Title: Painted area does not move along when the surface is moved
Post by: trimitek on January 08, 2016, 02:48:21 pm
Hi there,
Just started using Forest Pack Pro and loving it so far.
I just noticed something that probably needs to be fixed.
I had painted some areas on the surface I use for the plants, but I had to move it afterwards (on XY plane) and I found out that the painted areas stay in their original coordinates and does not move along with the surface.
Any way to avoid repainting them?
Title: Re: Painted area does not move along when the surface is moved
Post by: Michal KarmazĂ­n on January 08, 2016, 03:58:35 pm
Well, as that's not always desirable behaviour, by default the Paint Area (http://docs.itoosoft.com/display/FORESTPACK/Areas#Areas-PaintAreaProperties) isn't linked to the surface.
Anyway, it's easy to bind any Area(s) to the surface with the 3ds Max's Select and Link (https://knowledge.autodesk.com/support/3ds-max/learn-explore/caas/CloudHelp/cloudhelp/2015/ENU/3DSMax/files/GUID-4115DE9B-D636-4A42-904E-71259A843E0A-htm.html) function. Optionally, if wanted to not link the whole Forest object, you can use the Areas - Convert to Spline feature and Select and Link just that newly created & assigned spline.
Just take in mind, you'll need to click on the Update surfaces data button or mark the Auto check-box (to Update surface data automatically (http://docs.itoosoft.com/display/FORESTPACK/Surface#Surface-SurfacesList) - this may add a performance hit for complex surfaces) to rebuild the Forest object.
Hope that helps.
Post by: trimitek on January 08, 2016, 04:10:19 pm
Thanks for the great tips!
Excellent support as always :)
