Author Topic: Possible to invert "Limit to visibility" ?  (Read 5321 times)
Ramboll
« on: February 05, 2019, 09:06:15 pm »
I was wondering if it is possible to make the limit to visibility camera function to work backwards? I want to hide the items that are close to the camera and show the items that are further away?
Hope you have a solution for me!
Kind Regards
Bjornar I
Terri Brown
    • Terri Brown 3D
Re: Possible to invert "Limit to visibility" ?
« Reply #1 on: February 06, 2019, 08:25:14 am »
I would use the Distance Falloff Density parameter under Camera but invert the curve...I have had success with that in the past. But I'm sure the gurus at Itoo have a better workaround!
« Reply #2 on: February 06, 2019, 08:42:35 am »
You can use negative value of Back Offset. ForestPack Rollout does not allow You to enter negative value, but You can do that via maxscript
Code: [Select]
$.cambho = -20000
Ramboll
« Reply #3 on: February 06, 2019, 09:43:24 am »
Perfect, exactly what I wanted :D Hope you can implement this in the next release ;)
B
« Reply #4 on: February 06, 2019, 10:59:41 am »
It is implemented in current release. Feel free to use this trick with current version.
RealViz
    • RealViz
« Reply #5 on: February 07, 2019, 08:22:04 am »
Yes, but it can be without script?
« Reply #6 on: February 07, 2019, 11:29:44 am »
In current version there are two ways to achieve that already:
1. As mentioned by Terri Brown use density falloff:
2. Using LOD item:
Attaching scene for Your reference.
RealViz
    • RealViz
« Reply #7 on: February 07, 2019, 03:36:08 pm »
Yes, of course. I used this way in past. I just forgot. Thank you for reminding me. :-)
