Author Topic: User's Libraries issue  (Read 3157 times)
IT1371
« on: March 09, 2014, 03:28:54 pm »
A weird issue was discovered while setting up my libraries.
Whenever right-clicking any object and then Delete the selected object is not deleted.
It does poping up Yes/No question with the correct object mentioned, but instead something else is being erased.
Restarted max - didn't work.
Forest Pro version 4.1.6.
IT1371
Re: User's Libraries issue
« Reply #1 on: March 10, 2014, 08:00:42 am »
Sorry for the double post.
The workaround is to manually delete from the XML file.
Anyway issue persists.
« Reply #2 on: March 10, 2014, 09:47:26 am »
I can confirm there is some problem with Delete. Although i cannot reproduce exactly that issue, in our tests it removes the first object, not the selection.
I apologize by the inconveniences, we'll fix the bug. As you pointed, the workaround is to edit directly the XML.
