Toggle navigation
Login
Register
Forest Pack
Forest Pro (*)
Stepped rotation
« previous
next »
Print
Pages: [
1
Author
Topic: Stepped rotation (Read 3726 times)
ritoo
Jr. Member
Stepped rotation
on:
March 09, 2023, 06:52:31 am »
1. HI, I've got a Forest in path mode (@vertex) with stepped rotation effect applied. All is good but it rotates in world space. How do I make it respect the path orientation?
Should the effect code be altered somehow?
2. And, If I add the splines marked red on the second pic the stepped rotation get lost completely .
Thank you in advance
Last Edit: March 09, 2023, 07:40:07 am by ritoo
Logged
ITOOSOFT
Hero Member
Re: Stepped rotation
Reply #1 on:
March 09, 2023, 09:35:09 am »
Well, the mentioned effect is written for the
Distribution Mode. Please find a slightly changed version of it (
FEffects_AdditionalSteppedRotation.eff
), which “adds” the Stepped Rotation values for the
Path
Distribution mode. Another option would be to use the
Probability Curve
, for these purposes, which lets you define the probability of each random value in the rotation range.
Logged
ritoo
Jr. Member
Reply #2 on:
March 09, 2023, 10:42:29 am »
Thanks for assisting Michal! Have you tried the new effect on the forest I provided?
I played with all settings that could influence but there's no stepping whatsoever. No luck with probability curve either.
Last Edit: March 09, 2023, 11:03:01 am by ritoo
Logged
ITOOSOFT
Hero Member
Reply #3 on:
March 09, 2023, 03:09:29 pm »
Having the
Transform
Rotation
feature disabled, it seems to work just fine. Please find attached the modified scene (
230309_step_iToo.max
). I hope that helps.
Logged
ritoo
Jr. Member
Reply #4 on:
March 09, 2023, 03:48:49 pm »
Fantastic, Many thanks! Rather important thing, could it come with installation please?
Logged
ITOOSOFT
Hero Member
Reply #5 on:
March 10, 2023, 12:37:51 pm »
You're welcome. I'm glad to hear, that it helped, and wish you the best results. We’ll update it. Meanwhile, please find attached a slightly adjusted style.
Logged
Print
Pages: [
1
« previous
next »
Forest Pack
Forest Pro (*)
Stepped rotation
Welcome,Guest
1 Hour
1 Day
1 Week
1 Month
Forever
