Forest Pack => Forest Pro (*) => Topic started by: AtlJimK on March 25, 2015, 03:18:19 pm
Title: Problem with Imported Forests
Post by: AtlJimK on March 25, 2015, 03:18:19 pm
We are attempting to use VIZ Park's Field Grasses. These are prepared multiple forests assigned to a surface only. Once we import and assign to a new area and remove the original surface the forest will only randomly render. Some frames will have disappearing portions of the forest. This does not happen with new forests just imported ones. Short of re-creating the imported forests is there a fix? We have upped all of the "Max" items and faces to crazy high numbers.
Title: Re: Problem with Imported Forests
Post by: iToo on March 25, 2015, 04:49:59 pm
Hi, we have detected that some presets produced by VIZPARK were facing license issues and that might lead to unwanted behaviour of the plugin.
People from VIZPARK are informed about that problem and as far as we know, they already have reworked all affected files. Most probably, you've downloaded your files before that update.
Please contact directly with VIZPARK (http://www.vizpark.com/contact/) regarding that problem. They'll provide you correct files ASAP. Hope, you'll get working models soon and if there will be anything more we can help you with, please let us know.
Post by: AtlJimK on March 25, 2015, 05:11:40 pm
Ok, thanks for the quick reply.
