Forest Pack => Forest Pro (*) => Topic started by: Darwin Ceballos on January 13, 2017, 09:17:29 am
Have this problem with assigning a forest obj to a lofted road, does FP have issues with lofted objects?
file attached
Darwin
The object "Object001" in provided scene has inverted normals (polygons are facing downwards). Flipping normals will fix that.
Regarding Loft objects: We're able to reproduce problems when using a Loft object as a Surface for Forest's distribution - it occurs within the 3ds max core when the bounding box info required by our plug-in can't be accessed. Unfortunately, from our plug-in we don't have any influence over it.
As a workaround, please apply the Edit Poly (Edit Mesh) modifier over such object to avoid this unwanted behaviour.
I would encourage you to contact directly Autodesk (http://download.autodesk.com/us/support/report_a_bug.html?SelProduct=3dsMax) regarding this bug. Once they'll see, there is a real demand from their users, they'll prioritize that. I'm afraid we can't do much more in this case. Thanks for your comprehension.
Tnx for quick reply and for your help :D
cheers, Darwin
