Author Topic: Problem with opacity maybe  (Read 3257 times)
Kostas
« on: December 12, 2016, 01:10:26 am »
Hi team,
Does anyone know if this is caused by opacity? Half the leaves render ok. The other half render as if there is a hole there. It's kind of random. I've run the material optimizer for vray but it keeps appearing. This happens only in leaves that have opacity... How can I render them? Do I need to use only trees with geometry leaves?
Kind regards
Re: Problem with opacity maybe
« Reply #1 on: December 12, 2016, 11:44:24 am »
That looks like a "Backface Cull" issue. In case, you're using the V-Ray renderer and you've enabled the Global switches - Force back face culling option (by default disabled), switching it OFF should fix it.
Kostas
« Reply #2 on: December 12, 2016, 09:23:25 pm »
Hi Michal,
Today it worked. It wasn't the checkbox in vray global switches. I entered again the path to the textures and it worked. I must have missed something the first time??. Sorry for wasting your time...  :P
« Reply #3 on: December 13, 2016, 12:36:10 pm »
No worries at all. Glad to hear, that's working fine and wish you best results.
