Author Topic: Problems with Civil View Surfaces  (Read 5827 times)
dande
« on: May 09, 2013, 08:11:31 pm »
I have attached a file containing 2 identical civil view surfaces. Forest pack pro works fine on surface 1 but does not work on surface 2.
Any ideas why this is. I cannot find any difference in the surfaces.
3DS Max Design 2014
Forest Pack Pro 4.0.3
Re: Problems with Civil View Surfaces
« Reply #1 on: May 10, 2013, 09:05:40 am »
The Normals on Surface 2 are not oriented correctly. You should collapse it to Editable Mesh/Poly and apply a Normal modifier.
dande
« Reply #2 on: May 10, 2013, 09:24:23 am »
Thanks for you reply. That makes sense. I was wondering why it didn't work when I converted it to a mesh
« Reply #3 on: May 10, 2013, 09:46:22 am »
One more thing: we just realized it is possible to flip the Normals, reversing the base splines. So it is not necessary to collapse, if you want to keep the CV objects.
