Toggle navigation
Login
Register
Forest Pack
Forest Pro (*)
Suface dosent get Forset..
« previous
next »
Print
Pages: [
1
Author
Topic: Suface dosent get Forset.. (Read 2878 times)
yossivida
Newbie
on:
June 08, 2017, 07:18:39 am »
Hello i did vertical wall with forest ..
but when i chose the pink surface .. it dosent get the forest on it..
what i need to select to make it all walls covered by one forestpack modifier?
thank you!
Logged
amitgedia
Full Member
Re: Suface dosent get Forset..
Reply #1 on:
June 08, 2017, 09:56:45 am »
hi,
you need to check this tutorial
https://www.itoosoft.com/tutorials/scattering-on-vertical-surfaces?back=page%3D1%26tag%3Dfp
also make sure the co-ordinates are in the right direction
also check this post where i had a similar problem
https://forum.itoosoft.com/index.php?topic=4354.msg16896#msg16896
hope this helps
Logged
Print
Pages: [
1
« previous
next »
Forest Pack
Forest Pro (*)
Welcome,Guest
1 Hour
1 Day
1 Week
1 Month
Forever
