Forest Pack => Forest Pro (*) => Topic started by: GP4851 on November 08, 2016, 05:23:53 am
Title: question about "match color id on map"
Post by: GP4851 on November 08, 2016, 05:23:53 am
Hi,I have some problems with the following:I just learn the new tutorial"Scattering on Vertical Surfaces",and try to use "match color id on map" with a jpg on another plane which I made myself.But the pattern in the plane of tutorial  is correct .No matter how I adjust the density,the pattern is  changeless
 but when I use the jpg on another plane,,the pattern isn't correct,and when I change the density on distribution map,the pattern always changes.
Wonder how to solve it,Thank you ~~
Title: Re: question about "match color id on map"
Post by: Michal Karmazín on November 08, 2016, 12:44:40 pm
I would suggest you to check UV mapping of the problematic object / it's local coordinates (your surface coordinates should correspond with intended Forest object orientation) and that you're using the corresponding channel. Please feel free to send us (http://forum.itoosoft.com/index.php?topic=3648.0) your scene and we'll look at it here. Thanks in advance.
