		Forest Pack => Forest Pro (*) => Topic started by: allemyr on March 23, 2020, 07:29:11 pm
				Hi Itoo.
I would like to ask if its powwible to random transform objects inside a Forest Pack object less then 1.0 value, like random rotate between -0.5 to 0.5 for example.
I can only write hole integeres but need something around 0.2 to 0.2 in rotation.
Thx in advance!
				You can use custom Effect.
This will ranzomize Z axis from -0.5 to 0.5 degrees:
fpItem.rotation.z = degtorad(randomReal(-0.5,0.5));
				Hi, Thank you very much works great!
What would the same be for translation in small amounts don't what to write instead of degtorad, value?
				You can use already existing effects for that:
(https://i.imgur.com/26R6aSZ.png)
				Hi, I would like to randomly translate items say 0.5 values in the Z direction how do I do that?
I'am working on a brickwall with Forest Pack right now, placing bricks in spline vertex positions.
You can use "Translate in world units: effect and specify exact units in cm:
(https://i.imgur.com/cwWtcly.png)
Hope this helps.
				Hi again, thx for the repleis, helped a lot!
I also wonder If you on top of that can move random items 180 degrees to get more random bricks that I'am rendering right now. So a brick is rotated zero or 180 degrees in any axis, is that possible?
				Hi, There is another built-in Forest Effect called Stepped rotation that should be able to do that for you. You can see a little more about it here: https://docs.itoosoft.com/forestpack/forest-plugin/effects/effects-examples/stepped-rotation
You can add as many Forest Effects as you need
Hope that helps,
				Ok cool! Thats nice, I found the premade effect. But I also want to add it in Y and X axis.
When I paste the expression in the expression box I get compile error.
I'am pasting this:
real rotateRange = fpItem.randRotMax.z - fpItem.randRotMin.z;
real stepsInRange = floor(rotateRange/Z_Rotate_Step);
real ZRotation = randomInt(0,stepsInRange)*Z_Rotate_Step;
fpItem.rotation.z = degtorad(ZRotation);
I want to rotate randomly in 180 degrees to get more variation off bricks in all axis. I'am also rotating all the bricks with a value of 0.5 in all axis aswell, will that be overridden by "Stepped rotation"?
Thx in advance :) Really appriciate it!
				Compiler stops at unidentified variable. You need to define it first:
(https://i.imgur.com/dESOYxc.png)
