Author Topic: vray 7  (Read 13270 times)
djibvongenf
vray 7
« on: November 13, 2024, 07:57:51 am »
Hi all,
Im having an warning message from vray7 log ->
[07:53:31.942] Warning : Affected Nodes: Forest GAZON CYPRES
[07:53:31.945] Warning : Affected Materials: _fp_unkempt_lawn (Multi/Sub-Object), Chickweed Leaf (VRay2SidedMtl), forest_automat_D6AC070 (Multi/Sub-Object), Chickweed Leaf (VRayMtl)
[07:53:31.946] Warning : Affected Textures: Map #2138799893 (Forest Color)
[07:53:31.947] Warning : Export problem for 'Map #713 (Bitmap)' (Exported bitmap c:\users\XXXX\appdata\local\itoo software\forest pack pro\lib\presets\layered_lawns\maps\Chickweed yellow.jpg with blur=0.10 will render differently!)
Happening for all my forest object, also the preset ones.
the problem is the "will render differently"... i don't what the difference is but it looks very plastic.
Did someone encounters this warning message at least once?
Re: vray 7
« Reply #1 on: November 13, 2024, 10:25:03 am »
You're using the GPU version, correct? You can safely ignore this warning - the GPU version uses its own filtering, and the 0.1 Blur value is ignored. I hope this clears it up.
