Author Topic: ForestIvy Library Error when set to Automatic Mtl  (Read 1206 times)
SeanRedmond
« on: May 24, 2024, 07:45:17 PM »
Just a small issue i've found- if you are using a renderer other than corona, arnold, or vray then the default "automatic selector" option in the forest library will give you an error, because it seems there is no scanline mtl included. It works fine if you switch to one of the other renderers, but i thought there was an install error at first.
Re: ForestIvy Library Error when set to Automatic Mtl
« Reply #1 on: May 25, 2024, 10:30:25 AM »
Thanks for reporting it.
This is a placeholder for Scanline materials, but we haven't decided yet if it's worth creating them.
In any case, we'll improve that warning message.
