Forest Pack => Forest Pro (*) => Topic started by: RealViz on February 02, 2022, 03:00:02 pm
Title: Reference not working with pivot (FP 7.3)
Post by: RealViz on February 02, 2022, 03:00:02 pm
I've now noticed that FP does not respect the pivot manual offset of the ref. object in reference mode. The default pivot is still used.
Title: Re: Reference not working with pivot (FP 7.3)
Post by: Paul Roberts on February 02, 2022, 03:03:42 pm
Hi! It should work if you reset the XForm of the reference objects
Best,
Post by: RealViz on February 02, 2022, 03:16:25 pm
But that unfortunately ruins the object's rotation :-(
Post by: RealViz on February 02, 2022, 03:17:03 pm
I believe that previously this function worked normally without resetting xform.
Post by: Paul Roberts on February 02, 2022, 03:34:28 pm
I just checked this in Forest Pack 6, and it would appear to be the same as Forest Pack 7.3. I'll mention it to our dev team, but it may be something Max related over which we have little control.
Post by: RealViz on February 02, 2022, 04:50:27 pm
Thanks, maybe I'm just remembering it wrong. The best solution is to select the ref. obj. and then rotate/move them in the local.
