Forest Pack => Forest Pro (*) => Topic started by: UN4698 on December 20, 2019, 12:02:15 am
Render Slaves don't render Forest Pack after 6.1.2 update.
Is there a lic change? How do you set up the render slaves?
Vray distributed rendering worked fine this morning. Then I made the mistake of updating FP (on all machines), and now none of the slaves will render FP.
I am sorry to hear You are facing these issues.
There were no licensing changes between these versions.
I just checked and salve works fine with latest FP.
I would recommend You to check our network rendering troubleshooting guide (https://forum.itoosoft.com/faq/distributed-rendering-issues/).
I've checked all these things. It was working fine minutes before the update and hasn't worked since. I upgraded again to 6.2.2. I uninstalled it and reinstalled it 3 times. I can't figure out how to roll back to an older version. I do think something strange is going on because I couldn't find anyone else post the same issue. Is there an error log or something that would give more info?
Have You read the link i gave You:
Is it A or B in Your case?
A) Installation error.
B) Missing textures/proxies.
Roll back to an older version? Just reinstall older version on workstation + render nodes.
After multiple restarts of all computers it is finally working again. No other changes made.
Hopefully with 6.2.2 ?
Thanks for letting us know, what helped in Your case. Maybe it will be helpful for future cases.
