Forest Pack => Forest Pro (*) => Topic started by: PH4128 on July 26, 2012, 02:41:10 pm
Title: rendering problem when turn forest to custom edit mode
Post by: PH4128 on July 26, 2012, 02:41:10 pm
I working on an animation using forest for placing people in a mall. I need to turn forest to the custom edit mode for the final tuning. when forest is turn in edit mode I have render problem with the opacity of the people material (noise in the alpha) see image.
I use vray
someone have an idea?
Thx,
Fred
Title: Re: rendering problem when turn forest to custom edit mode
Post by: iToo on July 26, 2012, 04:44:27 pm
Theorically, there is not difference between generate and custom editom for the material.  But checking the image, it seems a coplanar faces issue.
Please, check if for some reason there are two overlapped planes for those billboards.
Post by: PH4128 on July 26, 2012, 11:09:02 pm
Hi itoo,
Thx foR your response! I have check, there is no overlapping face. Only 1 face wirh double sided matérial. One image in the diffuse slot and one in the opacity.
I have "slove" the problem by using a forest for each level (one for the ground floor and one for the 1th floor) before there was one forest for 2 level
Post by: iToo on July 26, 2012, 11:27:07 pm
Ok, anyway if you send us a test scene we would check it.
Post by: iToo on July 27, 2012, 12:41:46 pm
Thanks for the file. As i though, there are coplanar items in the 1th floor. You can check it entering in the sub-object mode, selecting a plane and moving it... there is a duplicate item in the same position.
Probably they were created by some copy operation, because the items in the ground floor are correct.
Post by: PH4128 on July 27, 2012, 01:47:24 pm
thank you!!!
