Forest Pack => Forest Pro (*) => Topic started by: EM3498 on March 09, 2021, 11:51:55 am
Hello
I know that this topic has been discussed few times.
We have version 7 now and I'm wondering if installation process for rendernodes is still the same?
I have 10 rendernodes and 3 workstations.
Network license.
I've downloaded the assets via the update manager to a network location from one of the workstations .
Next I've installed forest pack 7 manually using "Render slave node" on 10. render nodes
Then configured the render nodes to look for the assets in the network location, i've specified earlier.
Do I need to login in the Update Manager on each of the rendernodes ? or only specify the Local Network Installation, without being logged ?
Is that all what needs to be done ? Do I need to modify registry? or Configure the environment variables?
Greetings,
Greg
No major changes in FP7 from FP6. You can login via commandline as well.
I can only suggest to review our documentation (https://docs.itoosoft.com/installation/update-manager#UpdateManager-CommandLineInstallation).
Yes, should be still valid setup.
