Author Topic: Rotation in angles?  (Read 10087 times)
Nir Sullam
Rotation in angles?
« on: August 22, 2010, 11:02:50 am »
Can I force FPP objects to rotate in angles 0,90,180,270 ?
I am distributing chairs in the gardens of a multi-villas project.
Nir
Re: Rotation in angles?
« Reply #1 on: August 22, 2010, 11:17:17 am »
On defined angles by each item or randomly ?
For a random distribution, you can create four chair samples (rotated at 0,90,180, 270) and use them in the Geom List. If you need to rotate each chair a specific angle, the only way is to use the Custom Edit mode and scatter them using other object as reference (Creation Tools->Reference objects):
http://www.itoosoft.com/english/menu.php?id=forest_refedition
Nir Sullam
« Reply #2 on: August 22, 2010, 11:24:02 am »
I need to scatter them randomly (each with a different rect. angle)
OK I will try the solution but maybe you could add it to a future version.
Nir
