Author Topic: Scale error in forest  (Read 21525 times)
ben_img
« on: September 09, 2024, 02:40:00 pm »
Hi, please see attached render and max file (missing maps shouldn't affect the issue)
if you can recreate the issue, and know what is it :)
I found a solution to remove those big segment using the slope restriction. it seems to happen where two faces are on top of each other on the mesh
the main issue is that it's not visible in the viewport!
3dsmax 2023 (25.0)
forest 826
render engine fstorm latest
Re: Scale error in forest
« Reply #1 on: September 09, 2024, 03:25:41 pm »
Sometimes, as seems to be the case here, the presence of vertical polygons in the object can cause incorrect results when calculating the Surfaces > Scale to fit sloped areas. A recommended solution is to remove these polygons (see the attached modified scene 240909_forest_size_ITOOSOFT.max) or disable this feature. I hope this helps.
