Toggle navigation
Login
Register
Forest Pack
Forest Pro (*)
Scatter a X amount of object on a spline
« previous
next »
Print
Pages: [
1
Author
Topic: Scatter a X amount of object on a spline (Read 10247 times)
djibvongenf
Newbie
on:
June 22, 2024, 06:58:31 pm »
Hi All,
I can't figured out how to scatter, let's say, 22 objects on a circle. I can't find a way, or easier to say see, except to give them a fixed distance in between.
Anyone has a clue about this?
thank you
Logged
ITOOSOFT
Hero Member
Re: Scatter a X amount of object on a spline
Reply #1 on:
June 24, 2024, 08:43:00 am »
The
Path
Distribution Mode works in either
Spacing
mode (which requires adjusting the value accordingly) or
In Vertex Positions
mode (where you may need to add the corresponding number of vertices). For this type of task, the
RailClone
plug-in is more suitable. Within the
L1S Generator
, under
Properties
Rules
Evenly
, you can set the mode to
Count
Logged
RealViz
Sr. Member
Reply #2 on:
June 24, 2024, 04:36:24 pm »
Or you can use "Normalize Spline" and specify the number of vertices. Then enter "On Vertex position" in FP.
Logged
Print
Pages: [
1
« previous
next »
Forest Pack
Forest Pro (*)
Welcome,Guest
1 Hour
1 Day
1 Week
1 Month
Forever
