Forest Pack => Forest Pro (*) => Topic started by: UJ4448 on February 03, 2020, 06:42:35 pm
Title: Scattering lights with fores pack
Post by: UJ4448 on February 03, 2020, 06:42:35 pm
Hello guys,
Is there any way we could use forest pack to scatter Vray lights, the purpose of it is to be able to quickly illuminate towers or tall architectural buildings.
so far I have found some script called instance lights on forest, but if you change the parameters of the forest object, the instanced lights would not change accordingly.
is there a way to go around that ? will froset make the option available to scatter Vray lights, this might be pretty handy to a lot of us :D.
Best Regards
Title: Re: Scattering lights with fores pack
Post by: Rokas on February 03, 2020, 07:00:35 pm
Unfortunately non-geometric objects (as lights) aren't supported as items for distribution, therefore I would suggest you a "material work-flow".
Applying a VRayLightMtl (I suppose you're using the V-Ray renderer) / CoronaLightMtl (in case of Corona renderer)  for corresponding material.
Sometimes this workaround is enough.
Hope that helps.
Post by: FD7518 on September 15, 2020, 09:08:35 pm
Hi, Any plans to support scattering lights or it's impossible to do?  Thanks
Post by: Rokas on September 16, 2020, 08:33:44 am
Hi. Thanks for interest. Support to scatter lights will be available in ForestPack 7. FP7 beta is just around the corner.
