Author Topic: Gravel  (Read 2939 times)
Bobby Parker
Gravel
« on: September 09, 2016, 09:13:54 pm »
I am trying to add gravel to my driveway, but it isn't working. I tried grass, too, but it doesn't work. I have tried to export my driveway and import it, but nothing.
http://screencast-o-matic.com/watch/cDQQqXjQ9A
Re: Gravel
« Reply #1 on: September 10, 2016, 08:27:00 am »
Hi, i see 'F' icon is downwards, probably because the surface is flipped as well.
Please try applying a 'Reset XForm' to the surface and recreate the Forest object. That should fix it.
Bobby Parker
Re: Gravel
« Reply #2 on: September 12, 2016, 05:16:57 am »
Yeah, I tried all of that. I ended up rebuilding the surface.
Schellicon
Re: Gravel
« Reply #3 on: September 15, 2016, 04:06:50 pm »
workarround:
create a plane,
convert to edit mesh / poly
attach your geometry to the plane
go to sub mode and delete the plane
now you have the same geometry like before, but now everything is working!
if you use the surface modifier, you have to use this workarround , i think there`s a bug inside
(Every data inside the mesh is rebuilded /rewritten if you attach something , makes the fix)
