Author Topic: Suggestions for Forest Pack Tips and Tricks tutorials  (Read 562209 times)
Re: Suggestions for Forest Pack Tips and Tricks tutorials
« Reply #30 on: December 04, 2018, 01:39:21 pm »
RealViz Thanks for all Your suggestions. Keep them going, just please do not post this to Tutorials request topic.
Feel free to create new threads with Your ideas.
full-blood
« Reply #31 on: December 10, 2018, 07:08:22 pm »
I have a proposition for the presets. I don't know if there is already a way to do it.
It can be great if you can import only selected part, as just the "distribution" or "surfaces" data for exemple. As this you it can be quick to repeat the same to all forest objects.
QK1362
« Reply #32 on: February 18, 2020, 10:53:28 am »
Is it possible to scale the Forestpack around the exclude spline?
and will there be an official FStorm support for the existing libary?
thanks in advance...
« Reply #33 on: February 18, 2020, 03:56:55 pm »
Yes it is possible:
Attached max file.
Fstorm materals, we're aware of FStorm and we're keeping a careful eye on it, As you can imagine we already support a lot of render engines and we have only limited resources, so we have to focus on those that are most popular. That said as FStorm progresses, if a critical mass of users is reached we'll certainly look into it. Thanks for your comprehension.
SamR
« Reply #34 on: July 06, 2020, 11:20:06 am »
Apologies if I've put this in the wrong place. First time commenting on this forum.
I render using Vray GPU and have 2x 2080ti. So a total of 22GB to play with.
I have a project coming up that will have an incredible about of forest pack on a huge landscape..planting, grass, gravel, ponds..the works.
I've been looking online and I couldn't find anywhere a rundown of the best practices and techniques when using vray GPU with forest pack.
Obviously, I have limited memory and need to keep render times down (as much as possible).
So, I guess I’m just looking for tips and tricks to make sure I don’t run out of memory Midway through the project and more sure I’m not rendering for a week haha.
Hope that all makes sense and thanks in advance
Sam
JG_archviz
    • JG
« Reply #35 on: October 07, 2021, 01:39:15 pm »
not sure if its mentioned, but could you implement some thing like a sort by "name" function into geometry list? When i load multiple items via library, they don't always come sorted by name ... and if you got a bunch of them its kinda time consuming to order them for later selection.
« Reply #36 on: October 07, 2021, 04:14:20 pm »
Thanks for the suggestion - added to the wishlist!
swavec
« Reply #37 on: June 09, 2024, 10:26:44 pm »
Can we have hihlighted selection in ForestLister?
BK8837
« Reply #38 on: June 21, 2024, 08:23:07 pm »
Hi itoo,
Can you add an embed feature in FP, similar to RC?
Thank you!
John.McWaters
    • JohnMcWaters.com
« Reply #39 on: June 24, 2025, 03:23:13 am »
For the 'Limit to visibility' option under Camera, I think it would be helpful to have an 'hourglass' option where the field of view (FOV) extends from the front of the camera and another that extends behind the camera (so it would look like in hourglass shape from above), with parameters for each that allow you to set clipping distances, etc. This would be helpful when dealing with FP objects that are in reflections behind the camera without also creating more FP objects to the side that only slow down orbiting, etc.
RealViz
    • RealViz
« Reply #40 on: June 24, 2025, 04:56:47 pm »
Hi, would it be possible to add "detach as instance"? Because it often happens that trees for single shots change position/rotation etc. slightly. This is not possible inside FP. Now I need to make it as a detach in another FP and then convert it to isntance using FP_toolbox. Which is quite awkward and tedious.
Or if it would be possible to animate objects in the case of "Custom Edit" :-)
