Toggle navigation
Login
Register
Forest Pack
Forest Pro (*)
Select objects in the scene that are used in Forest Pro
« previous
next »
Print
Pages: [
1
Author
Topic: Select objects in the scene that are used in Forest Pro (Read 4939 times)
JI2645
Newbie
on:
January 14, 2021, 01:52:51 pm »
Hello there,
I need to select all the objects that a selected Forest Pro uses in Geometry tab.
I tried to search for answer before posting here with no success. Apologies if I missed it
Thank you!
Svetlin
Last Edit: January 14, 2021, 02:05:03 pm by JI2645
Logged
Hero Member
Re: Select objects in the scene that are used in Forest Pro
Reply #1 on:
January 14, 2021, 02:47:01 pm »
There is a quad menu option to select dependencies- geometry/surface/area:
Anyway it currently does not allow to select all geometry dependencies. You can do that with little helper tool
Forest Pack Toolbox
Last Edit: January 14, 2021, 02:57:36 pm by Rokas
Logged
JI2645
Newbie
Reply #2 on:
January 14, 2021, 03:40:58 pm »
This is amazing :-)
Thank you very much!
Logged
Neto
Newbie
Reply #3 on:
May 31, 2023, 04:22:47 am »
how to activate in quad menu???Thanks!!!!
Logged
ITOOSOFT
Hero Member
Reply #4 on:
May 31, 2023, 10:51:44 am »
Please try manually executing the
forestpack.ms
located under
C:\ProgramData\Autodesk\ApplicationPlugins\ForestPackPro2024\Contents\scripts\startup
by using
Scripting
Run Script...
to see if that helps.
Logged
Print
Pages: [
1
« previous
next »
Forest Pack
Forest Pro (*)
Welcome,Guest
1 Hour
1 Day
1 Week
1 Month
Forever
