Author Topic: The roof is too narrow  (Read 32559 times)
HU0164
« on: September 04, 2025, 05:22:28 pm »
Is there a solution to extend the roof ONLY in width so that the right and left edges can be seen protruding from the wall ?
Re: The roof is too narrow
« Reply #1 on: September 05, 2025, 10:48:27 am »
Configuring this is a bit more complex than it appears, as simply increasing the padding for these segments would result in clipping. To prevent this, a larger array must be generated. In the attached sample scene, prepared by my colleague Paul, a Numeric parameter has been added to the XSplineLength to produce a larger shape. I hope you find this useful.
HU0164
« Reply #2 on: September 05, 2025, 11:50:35 am »
Wow! Great! Exactly what I wanted.
I'm now going to try this tip on the other roof models.
Thank you.
