Author Topic: Ways to exclude in UV mode?  (Read 3450 times)
Lupaz
« on: July 18, 2022, 06:45:02 pm »
Hi there,
How would you exclude an area in the attached case?
Thanks.
Re: Ways to exclude in UV mode?
« Reply #1 on: July 19, 2022, 11:22:29 am »
As I recall, that render was done by applying the FP object to a UV surface. It's not currently possible to use exclude areas in that mode, but it something we're actually looking into improving at the moment.
Best,
Paul.
Lupaz
« Reply #2 on: July 19, 2022, 03:26:23 pm »
Thanks.
How about a distance map? Is that possible? For example, with Corona distance map and a volume in the area that I want to exclude from?
RealViz
    • RealViz
« Reply #3 on: July 19, 2022, 03:28:41 pm »
I think using a classic boolean or better tyBoolean will serve very well.
« Reply #4 on: July 19, 2022, 03:59:03 pm »
Thanks.
This should work if you use the distance map as a Distribution texture. Note that you generally need to set the FP object to world origin when using Distance maps in this way.
Cheers,
