Forest Pack => Forest Pro (*) => Topic started by: link3d on January 27, 2016, 11:16:54 am
Hi, we are creating an camera animation flying over a large landscape.
There are some very few single trees popping in (everytime we rerender, reproduceable), all of these trees are quite in the mid of view, surrounded by other trees, not at the very foreground ore sides (means it can´t be camera clipping). There are NO trees dissapearing, the trees show up from one frame to another, everytime we rerender, the same trees, the same frames.
used 3dsmax2016sp1, vray 3, forest 422
now 3dsmax 2016sp2, vray 3.3, forest 502 beta
still same problem
forest scattering with dense distribution map, density size=800 Meters, scattering 3d-trees (proxies), several include and exclude splines
Matthias
Hi Matthias,
Sometimes, using the Distance Falloff for animated camera could cause similar issues. Please have a look at your settings under Camera tab inside of Forest object.
If the problem persist, I would suggest to do a quick test using Forest Tools and do the export of your scattered geometry to instances. You can find it under Utilities panel - More ... - Forest Tools. For more detais, please see our on-line reference guide (http://docs.itoosoft.com/display/FORESTPACK/Forest+Tools). This way you can check that the problem happens during Forest object conversion or not.
Anyway, please feel free to send us your simplified scene (containing problematic Forest object(s)) through WeTransfer (https://www.wetransfer.com/) to support@itoosoft.com to analyse it here. Thanks in advance.
