Forest Pack => Forest Pro (*) => Topic started by: Macker on February 15, 2019, 01:56:55 pm
Title: Spline scatter - Different spacings per spline
Post by: Macker on February 15, 2019, 01:56:55 pm
Hey guys,
I'm using forest pro to populate a car park and it's working perfectly, scattering cars at 2400mm intervals - however this all goes awry when it comes to disabled spaces which are all 1200mm wider than a standard space.
What would be really useful would be the ability to set different spacings for different splines.
Is this something that could be implemented?
Chris
Title: Re: Spline scatter - Different spacings per spline
Post by: Rokas on February 15, 2019, 02:03:06 pm
You can do that with 2 ForestPack objects, or RailClone.
Post by: Macker on February 15, 2019, 03:11:37 pm
I'm aware I could do this with two forest pack objects, but would this not double up the amount of memory used?
Post by: iToo on February 15, 2019, 03:57:29 pm
No. To avoid this issue, we designed the plugin to share the geometry, between all Forest objects in the scene.
Post by: Macker on February 15, 2019, 04:36:55 pm
Excellent, thank you.
