Toggle navigation
Login
Register
Forest Pack
Forest Pro (*)
Split Forest
« previous
next »
Print
Pages: [
1
Author
Topic: Split Forest (Read 3522 times)
TATproductions
Newbie
Split Forest
on:
January 14, 2015, 12:11:54 pm »
Here's a regularly case we are facing :
- A scene assembler made a scene with multiple forest and regular topology
- The renderMan get this scene and made his shoots with it
- Sometime the renderMan want to extract some part of a forest to hide it or to make it has an isolated foreground.
The way we are making it at the moment is pretty tough : copy of the forest, create a spline to exclude in the first one & include in the other...
Would it be possible to make a futur feature or a possible easier workflow ?
Thanks !
Logged
http://tatprod.com/
https://www.itoosoft.com/stories/the-jungle-bunch
Administrator
Hero Member
Re: Split Forest
Reply #1 on:
January 14, 2015, 01:30:30 pm »
If you don't need to change the distribution, would set Forest objects in
Custom Edit
mode, select the items and attach or detach them using
Tree Editor tools
It's possible to revert to
Generate
mode and keep the distribution, although not obviously after applying attach/detach.
Logged
TATproductions
Newbie
Re: Split Forest
Reply #2 on:
January 14, 2015, 03:13:03 pm »
Yep indeed, this help a lot.
But we sometimes have a little difference between the two modes, especially when forest has specific Areas values, like falloff density and so...
Logged
http://tatprod.com/
Administrator
Hero Member
Re: Split Forest
Reply #3 on:
January 15, 2015, 09:29:04 am »
Thanks for letting me know. We'll check it.
Ideally both modes should generate the same result, but there are many parameters involved, so probably we missed some of them.
Logged
Print
Pages: [
1
« previous
next »
Forest Pack
Forest Pro (*)
Split Forest
Welcome,Guest
1 Hour
1 Day
1 Week
1 Month
Forever
