Toggle navigation
Login
Register
Forest Pack
Forest Pro (*)
Stepped rotation
« previous
next »
Print
Pages: [
1
Author
Topic: Stepped rotation (Read 3963 times)
ritoo
Jr. Member
Stepped rotation
on:
March 09, 2023, 06:52:31 am »
1. HI, I've got a Forest in path mode (@vertex) with stepped rotation effect applied. All is good but it rotates in world space. How do I make it respect the path orientation?
Should the effect code be altered somehow?
2. And, If I add the splines marked red on the second pic the stepped rotation get lost completely .
Thank you in advance
Last Edit: March 09, 2023, 07:40:07 am by ritoo
Logged
ITOOSOFT
Hero Member
Re: Stepped rotation
Reply #1 on:
March 09, 2023, 09:35:09 am »
Well, the mentioned effect is written for the
Distribution Mode. Please find a slightly changed version of it (
FEffects_AdditionalSteppedRotation.eff
), which “adds” the Stepped Rotation values for the
Path
Distribution mode. Another option would be to use the
Probability Curve
, for these purposes, which lets you define the probability of each random value in the rotation range.
Logged
ritoo
Jr. Member
Reply #2 on:
March 09, 2023, 10:42:29 am »
Thanks for assisting Michal! Have you tried the new effect on the forest I provided?
I played with all settings that could influence but there's no stepping whatsoever. No luck with probability curve either.
Last Edit: March 09, 2023, 11:03:01 am by ritoo
Logged
ITOOSOFT
Hero Member
Reply #3 on:
March 09, 2023, 03:09:29 pm »
Having the
Transform
Rotation
feature disabled, it seems to work just fine. Please find attached the modified scene (
230309_step_iToo.max
). I hope that helps.
Logged
ritoo
Jr. Member
Reply #4 on:
March 09, 2023, 03:48:49 pm »
Fantastic, Many thanks! Rather important thing, could it come with installation please?
Logged
ITOOSOFT
Hero Member
Reply #5 on:
March 10, 2023, 12:37:51 pm »
You're welcome. I'm glad to hear, that it helped, and wish you the best results. We’ll update it. Meanwhile, please find attached a slightly adjusted style.
Logged
nubo
Jr. Member
Reply #6 on:
Today
at 02:40:22 pm »
What should I modify in the effect to make it respect also the surface normal?
Right now it respects the path direction but some of the rotated objects get really weird rotation depending on the angle of the surface.
The objects that don't get any rotation are aligned to the surface correctly.
I tried manipulating fpItem.surfNormal attribute but I'm bad at vector math.
Przemek
Logged
Print
Pages: [
1
« previous
next »
Forest Pack
Forest Pro (*)
Stepped rotation
Welcome,Guest
1 Hour
1 Day
1 Week
1 Month
Forever
