Author Topic: This is a MAJOR, MAJOR problem.  (Read 10007 times)
DK1217
Re: This is a MAJOR, MAJOR problem.
« Reply #15 on: June 14, 2018, 11:57:55 am »
What is everyone doing to make it work? I'm still getting Error04 for the starter library. Everything else has updated ok.
UPDATE: Restarted update manager. Seems to be downloading the starter library now.
« Last Edit: June 14, 2018, 12:00:18 pm by DK1217 »
« Reply #16 on: June 14, 2018, 12:12:53 pm »
We believe we fixed the problem.
Please Try now.
yanosh HRDY
« Reply #17 on: June 14, 2018, 03:28:57 pm »
everythings working now... ;)
BL_zoomvp
« Reply #18 on: July 04, 2018, 01:22:03 pm »
Hi.
I'm sorry but, I have still got the same problem on some machines.
"Error 13: Network error SSL handshake failed"
I have copied the files manually, as described in your documentation, but somehow the maps are not included?
So I  can't use any preset of your great libary.
Is there any solutions for this problem?
Other topic:
It's quite confusing to have 2 different Update Manager (one for FP and one for FP).
For instance there are differet ways to do the "offline" Installation.
Which got me a knot in my brain.
I couldn't figure out how to do the offline installation.
Thank you in advance!  :)
« Reply #19 on: July 04, 2018, 03:34:18 pm »
Please try to install the "comodo_ca.crt.cer" certificate as explained in this post. That might fix it.
As you've pointed out, there are several possible ways to install the plug-in itself and bundled assets - you mind find quite useful this detailed description of how to "use a shared network path".
Hope that helps.
BL_zoomvp
« Reply #20 on: July 04, 2018, 06:27:05 pm »
Thank you.  :D
