Forest Pack => Forest Pro (*) => Topic started by: CT2957 on October 10, 2013, 12:44:44 pm
Title: Sub object will not be selected
Post by: CT2957 on October 10, 2013, 12:44:44 pm
in the GEOMETRY MENUE want to add an CUSTOM OBJECT, which contains several subobjects. I already made a GROUP, but when I try to pick the group, only one of the subobjects is selected, not the group !
I´m a beginner in 3ds Max, thank you for your help.
Title: Re: Sub object will not be selected
Post by: iToo on October 10, 2013, 01:19:18 pm
If the group must be handled as single element (as a tree), you must attach all objects in an unique mesh.
Although Forest supports groups, they are handled as individual elements (basically to create clumps of grass, flowers and so). You can see a sample in the Forest 4 demoreel. In this case, groups must be selected by name.
Post by: CT2957 on October 10, 2013, 02:08:14 pm
That`s not the solution in my case:
I import a car model ... when I import the car model as a group like it´s demonstrated in the demo reel you mentioned, the four wheels, interior etc will be distributed separately .  I want to keep the car in one piece, of course. What can I do ?
Post by: iToo on October 10, 2013, 02:47:25 pm
As i said, if the object is used in the distribution as a solid element, you must create an unique mesh attaching all group elements, before assigning it to Forest.
Post by: CT2957 on October 10, 2013, 03:34:32 pm
Perfect, now it works. Thank´s a lot !
