Toggle navigation
Login
Register
Forest Pack
Forest Pro (*)
Surface Maxscript
« previous
next »
Print
Pages: [
1
Author
Topic: Surface Maxscript (Read 4716 times)
DN4548
Newbie
Surface Maxscript
on:
July 02, 2014, 08:04:51 pm »
Hi All, I'm sure this one is really simple but I'm just not sure where to find it. I'm trying to create a forest pack then assign a surface just like you would in the manual method. So far I have this:
Forest_Pro iconSize:1 camfar:100000 cambho:10 camdensfar:1000 clusize:20 altmin:-100 altmax:100
select $Forest001
$.reserved2 = $Plane001
John
Logged
DN4548
Newbie
Re: Surface Maxscript
Reply #1 on:
July 02, 2014, 11:43:42 pm »
This isn't working either. Ah must be so simple!!
tmp_ground=plane pos:[0,0,0] name:"Plane002"
FP4_obj=forest_pro mode:1
FP4_obj.surflist=$Plane002
Logged
Administrator
Hero Member
Reply #2 on:
July 03, 2014, 09:24:07 am »
Yes, as you pointed the surfaces are defined in "surflist", but this parameter is an array. So items are added using "append":
append ($Forest001.surflist) $Plane001
Probably you also want to enable the "Surfaces Area" (if not, there are not visible items). It's done in this way (assuming there are not other areas):
$.pf_aractivelist[1] = true
Logged
DN4548
Newbie
Reply #3 on:
July 03, 2014, 10:31:35 am »
Cheers, That works perfectly!! I'm sure I'll be back with some questions soon.
Logged
DN4548
Newbie
Reply #4 on:
July 04, 2014, 02:58:26 pm »
Ah, told you I would be back.
How do you had multiple items to the surface in 1 line of code for example
append ($.surflist) ($Plane, $Plane003, $Plane002)
Not
append ($.surflist) $Plane
append ($.surflist) $Plane003
append ($.surflist) $Plane002
Cheers,
John
Logged
Hero Member
Reply #5 on:
July 04, 2014, 03:25:20 pm »
it's not exactly oneliner but:
myarray = #($plane001,$plane002,$plane003,$plane004,$plane005,$plane006,$plane007)
for obj in myarray do append ($.surflist) obj
Logged
Print
Pages: [
1
« previous
next »
Forest Pack
Forest Pro (*)
Surface Maxscript
Welcome,Guest
1 Hour
1 Day
1 Week
1 Month
Forever
