Forest Pack => Forest Pro (*) => Topic started by: RealViz on May 21, 2024, 01:25:24 pm
Title: Transform accuracy
Post by: RealViz on May 21, 2024, 01:25:24 pm
Hi, would it be possible to add to the accuracy of the transforms? For example, if I am distributing seats in a stadium and I want to rotate them slightly (for a more realistic look) even a 1° tilt is too much. Would it be possible to enter values in tenths/sevenths? Thank you
Title: Re: Transform accuracy
Post by: Michal Karmazín on May 21, 2024, 02:04:26 pm
You should be able to use significantly lower values, corresponding to the units defined in the Customize > Units Setup window. If you're using the Numeric Operator, please ensure it is set to the Float or Scene Units type (not Integer). That should help.
Post by: RealViz on May 21, 2024, 03:43:37 pm
Yes I also thought it was by assigning a different operator. Unfortunately neither works for some reason. Not a problem with you in "." and "," we use Czech environment. Anyway, I also tried "." and ",".
Everything works OK in the whole 3ds max environment. Just not for transform FP :-(
Post by: RealViz on May 21, 2024, 03:56:07 pm
Video: https://youtu.be/bt0TxjcNqEs (https://youtu.be/bt0TxjcNqEs)
Post by: Michal Karmazín on May 22, 2024, 10:42:01 am
My apologies, I didn't realize that this is the Forest Pack Pro board. I was mistakenly thinking about the RailClone plug-in.
As you've noted, Transform spinners handle integer numbers, which are generally precise enough for random values within that range. However, for cases requiring a very small range, there's a simple workaround using Effect (https://docs.itoosoft.com/forestpack/forest-plugin/effects) for such scenarios. I've attached a simple example of the "realNumberRandomRotation" effect for randomizing the Z Rotation (similarly applicable to other axes if necessary) using real numbers.
Post by: RealViz on May 22, 2024, 11:33:40 am
