Author Topic: Pinestraw  (Read 13314 times)
Bobby Parker
Pinestraw
« on: May 20, 2024, 11:35:05 pm »
My pine straw is rendering white. I have the texture, but it doesn't seem to be applying it. I have had this issue with other things, but stopping and starting a render fixes it. With the pine straw, that isn't the case. I am using V-Ray GPU.
« Last Edit: May 20, 2024, 11:43:59 pm by Bobby Parker »
Re: Pinestraw
« Reply #1 on: May 21, 2024, 08:43:39 am »
Hi Bobby,
I'm sorry to hear you're facing these troubles. It might be that you're using the Forest Color map and currently, the Forest Color map is only partially supported by V-Ray GPU - using the Get Color from Map feature with Random values or As a texture on the Surface is not supported at the moment.
Thanks in advance for any further comments on this issue that you can share with us or our user community (in case some users encounter similar troubles).
