Forest Pack => Forest Pro (*) => Topic started by: KM2828 on March 14, 2012, 10:18:57 pm
I have a fairly complicate file that in the animate camera, one frame the trees are on, the next they are not, and the one after that they are on again. I have several forest objects, and they all turn off near and far in the display. It renders this way as well.
I have tried to turn off the occlude by camera, density, and merging the xref. Nothing seems to work. Any ideas?
I have attached the two frames so you can see what i mean.
Please, try to isolate the problem in a separate scene including only the essential objects (trees, splines and so). If it fails, send us the Max scene to check it.
My file is too large to post, should I send it to you via email?
You can use our FTP server. I just sent to you the login credentials by email.
