Forest Pack => Forest Pro (*) => Topic started by: iCreateLtd on June 03, 2019, 10:36:48 am
Hi.
I'm creating a stadium. I'm using FP to distribute characters.
For the seats, I have the top faces of where the character sits (just squares)
I've set distribution to Reference.
I've selected the seats object
I've set it to face centres
It's assigning 2 characters per face/object.
For clarity, I'm using a cube for this image
(https://i.ibb.co/n64f2gx/POLY.jpg) (https://ibb.co/34VWXrg)
How can I tell it to assign just 1 character.
The seats object is an editable poly. It's not triangulated.
There are only 4 vertices per face (seat)
Any ideas?
Thanks for question. Forest Pack distributes items per face(Center of 3 verteces), not per polygon. Every Quad polygon has two triangle faces.
Hope this explains how ForestPack works.
Hi.
Thanks for the reply.
Can you think of any way I can get around this?
Thanks again
Hi. you can explode current mesh to separate objects:
convert to mesh explode to objects:
(https://i.imgur.com/5RSbLiF.png)
Recenter pivots
Then Clone and align a new "triangle face" with clone and align tool:
(https://i.imgur.com/UA3jZTw.png)
Hope this helps
