Author Topic: vray 6 compatible?  (Read 14764 times)
Uwe Kreuzahler
  • 3D Visualization Director
    • 3D.CR
vray 6 compatible?
« on: July 07, 2022, 07:56:39 pm »
is the latest FP version compatible with V-Ray 6?
Photorealistic Architectural Visualizations
www.3D.cr
Re: vray 6 compatible?
« Reply #1 on: July 07, 2022, 07:58:23 pm »
Hi!
The latest versions of Forest Pack and RailClone have experimental support for V-Ray 6. Let us know if anything isn't working as it should.
Cheers!
P. Ham
« Reply #2 on: July 07, 2022, 11:55:53 pm »
Unfortunately it crashes 3ds Max (2023) for me.  Actually, if I start an interactive rendering it will crash 3ds Max immediately.  When I do a normal render it causes the rendering to stop immediately and then FP breaks.  3ds Max continues to run fine but the Forest Pack settings become unresponsive.
« Reply #3 on: July 08, 2022, 09:23:08 am »
Apologies, we need to make some changes. Expect an update soon.
Cheers,
Jorish
« Reply #4 on: July 08, 2022, 10:39:20 am »
Looking forward to the updated version with Vray 6 compatibility. Max 2023 crashes when using IPR, and shows a black render when using normal bucketrendering. With the forests hidden, everything is fine ;-)
MH4288
« Reply #5 on: July 09, 2022, 09:29:24 am »
VRay 6 is officially out, waiting for final FP release with VRay 6 support.
Jorish
« Reply #6 on: July 09, 2022, 12:10:18 pm »
Excellent job with the very fast 7.4.3 update guys! Seems to be working perfect with Vray 6 and Max 2023 over here. Haven't tested it to the max, but at first glance it looks good!
P. Ham
« Reply #7 on: July 13, 2022, 09:36:03 pm »
Can confirm.  Works great!
Theo
« Reply #8 on: July 20, 2022, 11:40:33 am »
We are experiencing a few crashes with FP 7.4.3 in Max 2021 with VRay 6. Interactive appears to be very unstable with FP. Moving a camera can cause the scene to crash and sometimes will just crash when trying to start the scene.
its been narrowed down to forestpack as when they are hidden it works fine. two colleagues currently experiencing crashes the most, while i have experienced none. same software setups.
« Reply #9 on: July 20, 2022, 12:32:40 pm »
Hi Theo, thanks for the report. Next time a crash happens, please send the minidump to helpdesk@itoosoft.com with details on what you were doing when it crashed. If you have a simplified scene that reproduces it as well - even better.
Many thanks,
Theo
« Reply #10 on: July 20, 2022, 02:16:17 pm »
Many thanks,
No problem will do!
« Reply #11 on: July 21, 2022, 10:01:03 am »
Thanks for the files.
Checking the minidump, crash seems to happen in the V-Ray side.
We have forwarded the issue to the ChaosGroup team.
Elighter
« Reply #12 on: July 24, 2022, 07:01:46 pm »
I'm having the same issue here w/ FP and RC.  Vray 6 w/ max 2023.  Cant start an ipr session w/o it crashing w/ a FP or RC object in the scene.  I already escalated to the Chaos team as I tried renders w/o those elements and max,vr run fine.
« Reply #13 on: July 25, 2022, 11:13:20 am »
Thanks for confirming. Hopefully, we can work with Chaos to solve it soon.
Best,
orejas77
« Reply #14 on: July 28, 2022, 12:37:00 pm »
Hello, I just updated to FP 7.4.3 on 3ds max 2021 and vray 6 and it is not compatible. Is there a trick I am missing?
Thank you
