Forest Pack => Forest Pro (*) => Topic started by: Bobby Parker on March 12, 2020, 11:05:01 pm
Title: VRay GPU
Post by: Bobby Parker on March 12, 2020, 11:05:01 pm
My colors are way off when using GPU. I am using tan and brown gravel, but it is rendering black and white. This works with CPU, so it isn't a path thing.
Title: Re: VRay GPU
Post by: Bobby Parker on March 12, 2020, 11:05:21 pm
Here is what I am using
Title: Re: VRay GPU
Post by: Michal Karmazín on March 13, 2020, 10:38:44 am
Would you mind to specify your actual software configuration (3ds Max, FP & V-Ray versions used)? Thanks in advance.
Title: Re: VRay GPU
Post by: Bobby Parker on March 16, 2020, 09:56:59 pm
Well, I can say the latest in them all. 3DS MAX, VRAY and Forest
Title: Re: VRay GPU
Post by: Rokas on March 17, 2020, 08:22:20 am
I have just doublechecked and it works fine here:
(https://i.imgur.com/pjWbOCI.png)
Would You please archive misbehaving ForestObject and attach it here or send (https://forum.itoosoft.com/faq/how-to-send-a-file-to-itoo-software/) it to us to doublecheck.
Thanks.
Title: Re: VRay GPU
Post by: SamR on July 06, 2020, 11:16:36 am
Apologies if I've put this in the wrong place. First time commenting on this forum.
I render using Vray GPU and have 2x 2080ti. So a total of 22GB to play with.
I have a project coming up that will have an incredible about of forest pack on a huge landscape..planting, grass, gravel, ponds..the works.
I've been looking online and I couldn't find anywhere a rundown of the best practices and techniques when using vray GPU with forest pack.
Obviously, I have limited memory and need to keep render times down (as much as possible).
So, I guess I’m just looking for tips and tricks to make sure I don’t run out of memory Midway through the project and more sure I’m not rendering for a week haha.
Hope that all makes sense and thanks in advance
Sam
Title: Re: VRay GPU
Post by: Paul Roberts on July 06, 2020, 12:21:11 pm
Thanks for the question. Rendering on the GPU shouldn't be too different from rendering on the CPU in terms of how to optimize. There are a couple of things to keep in mind.
You might also find this tutorial of use: Tips for Mastering Large Scale Environments (https://forum.itoosoft.com/Tips for Mastering Large Scale Environments)
You should also take a look at what features are supported in V-Ray GPU (https://docs.itoosoft.com/forestpack/requirements). Due do some technical limitations animation, edge mode, and tint by element are not supported.
I hope that helps,
