Author Topic: VRay Next is out  (Read 7220 times)
MH4288
VRay Next is out
« on: May 23, 2018, 10:19:14 am »
please when we can expect final version of FP for final V-Ray Next?
Thank you.
Re: VRay Next is out
« Reply #1 on: May 23, 2018, 11:24:41 am »
It should be released in coming weeks. We will have beta with v-Ray Next support sooner.
GT4505
    • claar.be
« Reply #2 on: May 30, 2018, 01:08:33 pm »
Same question here, as I've upgraded my licenses next licenses as the beta's were about to expire.
Now I can't revert to the beta combination.
A temp fix would be very much appreciated!
Pieter van Stee
« Reply #3 on: May 30, 2018, 02:02:36 pm »
Hi, you can use FP 6.0.8 beta and RC 3.1.8 beta. Both support V-Ray Next final.
There will be no significant differences between these betas and the final versions.
We're working only in the Update Manager and the libraries.
FF7689
« Reply #4 on: May 30, 2018, 10:53:01 pm »
Will work done in the beta be compatible with the final release? I'm thinking that I might be better off removing all traces of iToo from my active projects until the final releases are available.
« Reply #5 on: May 31, 2018, 08:33:19 am »
Yes. We have not plans to make more changes in the plugins.
All scenes created with FP6 beta will be compatible with the final release.
amitgedia
« Reply #6 on: May 31, 2018, 10:30:36 am »
i might be a little off topic but just a suggestion that in the final release just make sure to add some more vegetation libraries, presets or some more archmodels compatibility
« Reply #7 on: May 31, 2018, 11:28:25 am »
Thanks for the suggestion.
Forest Pack 6 has an all new tree library, plus green walls and more grasses. More is planned too. Thanks to Update manager we will no longer have to wait for a plugin update to release new libraries.
Cheers!
amitgedia
« Reply #8 on: June 03, 2018, 07:30:08 am »
Hi Paul,
Thats really good news because for architectural visualization we often require foliage libraries and other common architectural blocks which is easy to use if FPP has them as a ready library...
Thanks again and looking forward for the final release soon
