Forest Pack => Forest Pro (*) => Topic started by: JTP Vis on June 16, 2015, 12:22:03 pm
Title: VRay proxies versus geometry
Post by: JTP Vis on June 16, 2015, 12:22:03 pm
The question is simple:
Which works best for Forest Pack: VRay Proxies or Max geometry?
What are the benefits of either?
Bill
Title: Re: VRay proxies versus geometry
Post by: Michal KarmazĂ­n on June 16, 2015, 12:36:33 pm
Hi Bill,
The performance is almost the same and there are only some differences in memory impact - as a general rule, we suggest to use regular objects. In all cases Forest transforms the data to VRay's native render primitives. In this "mesh or proxy?" (http://forum.itoosoft.com/index.php?topic=863.msg2861#msg2861)  post you can find a detailed pros and cons between objects / proxies comparison.
Hope you'll find it useful.
Best regards
Post by: JTP Vis on June 16, 2015, 12:41:23 pm
Thanks for the reply. I did try a search to see if it had been asked before, but I obviously didn't search for the right things.
Bill
