Forest Pack => Forest Pro (*) => Topic started by: roysgi10 on March 31, 2019, 05:45:41 pm
Greetings
See attached file.
The object consists of several elements and the material is a vray with vraymultisub tex.
When I create a forest from this object, it uses only the first texture of the material and does not consider the rest.
The max file is also included.
FP: 6.1.5
VRAY: 3.60.04
MAX 2018
It is not recommended to use VRayMultiSubTex with Forest Pack due to the way the plugin redistributes IDs. If you must use it there are two options.
Firstly, you can disable Forest Pack's automaterial features by unchecking Consolidate materials. Be aware though that you will now need to manually create a single multi-sub object material, assign IDs manually and assign it directly to the Forest Pack object.
Alternativly, if the number total of items is not huge, use Forest Tools (https://docs.itoosoft.com/forestpack/forest-tools) to create instances of the source objects. Since the IDs are not modified, you can apply VRayMultiSubTex without changes.
