		Forest Pack => Forest Pro (*) => Topic started by: 3DG on January 30, 2023, 11:08:25 pm
				Gentle Itoo, I'd like to know if you are planning to enable the visibility of the forest pack objects in the VrayStereoscopic asset, because at now the rendering is not working with your stuff.
 I've done a quick test here and it seems to work just fine. As it's really hard to say, what's happening exactly in your scene just from the provided description, if possible, please feel free to send us (https://forum.itoosoft.com/faq/how-to-send-a-file-to-itoo-software/) your scene (ideally simplified and containing just this problematic object(s)) to helpdesk@itoosoft.com to check it here. In case of a big file size, please use a web-sharing service like WeTransfer. Ideally, if you'll be able to reproduce it on a minimal scene, which you can send us, it would be great.
 Thanks in advance for any further details you can share about it with us / our user community (in case some user(s) will run into similar troubles).
