Forest Pack => Forest Pro (*) => Topic started by: Tom_1028 on June 17, 2024, 11:26:25 am
Hi everyone,
I created a Forest Pack object using Spline distribution mode to scatter plants along a spline. It works fine.
Then I created a preset out of this scene.
But when I use the preset in a new scene, I have the message: "Warning: can't find object "" in the source scene". I hit Ok.
A Forest object is created but no objects are scattered. Plus the Forest items appear on the "0 (default)" layer instead of appearing on the usual forest_templates layer.
Can you please help?
Thanks in advance,
Hi Tom,
I'm sorry to hear you're facing these troubles. Could you briefly describe how you created the preset? I've done a quick test with the "Import Objects from Scene... (https://docs.itoosoft.com/forestpack/forest-library/editing-a-library#to-add-a-new-object-or-preset-to-a-library-from-the-scene)" feature, and everything seems to be working fine. Thanks in advance.
Thanks for your support, it's highly appreciated.
To create a preset:
_ I select the Forest Pack object
_ I copy it in a new empty scene (I use a Copy/Paste script found on scriptspot.com)
_ I save the scene in the "objects" folder of the chosen Library folder
_ I collect and relink all the assets
_ I create a thumbnail
_ I create the item in the Library by doing: Create item > Create 3D Object
_ I manually fill the necessary information in the "Properties" of the item
I have to say your method is way faster and convenient, thanks for that.
So I followed your link and created the preset using "Import Objects from Scene..." but it gave the following error:
"Scene File Save Warning: Unable to rename temporary scene file E:\My_Itoo_Presets\...........\objects\xxxx.max.sv$ to scene file E:\My_Itoo_Presets\...........\objects\xxxx.max"
So I hit OK and visibly the process didn't come to an end as I found a temporary file with a .max.sv$ extension instead of the file name I filled in the "Import Objects from Scene..." dialog box.
At that point I renamed the extension of the temporary file to .max, so that it can be found by Forest Pack, and I opened a new empty scene and tried using the preset: it failed with the exact same behavior as I first described:"Warning: can't find object "" in the source scene" + no objects were generated by the Forest Pack object.
PS: I double check I could open the .max: it's working fine. I can modify the Forest pack object, it's rendering well.
In that case, could you please send us (https://forum.itoosoft.com/faq/how-to-send-a-file-to-itoo-software/) your scene so we can check it here? Thank you in advance.
Replied by email.
Thanks for your quick answer and support all the time, really appreciated 👍🏻
Hi!
I actually have the same problem creating and using an own preset. Can you please share your solution?
Thank you so much!
Is it possible you're using 'empty Custom Object(s)'? If that's the case, please use the 'Disabled' option instead. I hope that helps.
indeed i did, but that didn´t solve the problem
Any other idea?
If possible, send us (https://forum.itoosoft.com/faq/how-to-send-a-file-to-itoo-software/) a simplified version of your scene, and we’ll check it here. Thanks in advance.
Hi! It solved the problem. Thank you.
(Yesterday I accidently saved the changed preset in the wrong folder)
