Author Topic: Weird Behaviour - Trees Cropped  (Read 3618 times)
SC3393
« on: December 05, 2022, 02:56:05 pm »
I´m facing this problem with forest pack.
When I render this image, some trees are cropped, as you can see by the following images attached.
I´ve created two groups of trees, on two different planes.
Need some help here.
Thanks in Advance
Re: Weird Behaviour - Trees Cropped
« Reply #1 on: December 05, 2022, 03:13:33 pm »
That’s really strange. Are you facing trouble by rendering locally / using network rendering or with distributed rendering? As it's really hard to say, what's happening exactly in your scene just from the provided images, if possible, please feel free to send us your scene (ideally simplified and containing just this problematic object(s)) to helpdesk@itoosoft.com to check it here. Thanks in advance.
RealViz
    • RealViz
« Reply #2 on: December 05, 2022, 03:21:11 pm »
I think this is a common mistake with Max trasnp. level at V-ray. Just increase it to e.g. 150.
SC3393
« Reply #3 on: December 05, 2022, 03:38:24 pm »
Thanks for your help Michal & Real Viz  :D
Your Tip for increasing the values Global Switches ---> Max. transp. levels from 50 to 150 worked out fine.
Once again thanks.
Kind Regards
